Front End Hinge Pin Drama
TampaBigRed
I used a 5/32" saw chain file (thanks for that awesome tip, y'all) to ream the arms, and the pins drop through freely. Got the front end put back together, and while it moves up and down easily, it's still a bit bound up. It has some droop, but it's not like the rear end. In a fit of rage, I ordered the aluminum A and B blocks. ... they'll be here Saturday. 😂 Is this something that'll wear in, or do I need to keep investigating what's causing it to bind up? Please help this poor frustrated noob.
Are you checking for binding with the shocks disconnected?
Yes - and I think I figured it out. I upgraded to the aluminum blocks, reamed out the pills a little more, and loosened the drop screws 1/4 turn. That released the heavy bind - I think the rest will release when it breaks in a bit more. Thanks for checking on me! :)
