First 3 packs
76jimmy
I'm totally happy with this et410.2. I pre-ordered the kit last year and never put it together. Finally got it assembled and put it through its first 3 packs on an outdoor 1/8 track.
Track is totally washed out and unprepared and I was smiling the whole time. Used a set of premount duratrax punch sct tires. They actually hooked up pretty good on The bombed out track. Electronics are max10 esc, HW 3660 4600kv sl motor, Savox 2273sg-ce servo and intellect 6200 lipo. Started with a 16t pinion I think I could go up a tooth or two. Straight is over 100' and the truck gets a little small on the back stretch but I couldn't be happier with this mini truggy. Box setup was just fine for some fun laps. I'd get into some different wheels and tires if I were to race it. I'm so impressed with my first tekno.
How was your heat with that motor esc setup. I run the same esc and can size but 3200kv in my Senton but was looking to swap them over.
Motor was 140° on a 18t pinion after 10 min run. Temp outside was about 80°. Esc was about 120°. Also switched to durratrax Pistol st premount wheels 1/2 offset.
