Vitavon MT48 2.0
RC-Steve
Vitavon has gone in deep with the MT48 2.0. I don't see Tekno listed on their menu. If you search "MT48" the whole catalog comes up. If you search "Tekno" only half the catalog comes up. I just order a set of ring gears. At some point I'm going to pick up some of their driveshafts.
Are these actually an upgrade over stock though?
I have them on my Kraton with a 4990 motor and on my Sledge with a 1717 motor. Vitavon ring gears are the best you can buy. My problem is I'm running Arrma 6s Backflip wheels and they're too much for the stock ring / input gears.
Look at them spiral cut dandies 😎
I'm guessing they cost more to make/machine than run of the mill straight cut gears.
I disagree! I bought the Vitavon gears for my Sledge and they didn't fit the stock or even their own bulkheads. The mesh was incredibly tight! Got no response from Vitavon about it... Swapped to the Traxxas upgraded ones, perfect.
I use the the 6s backflips on my ET48 and MT48 without issue. ADU/AllRacing bulkheads and stock ring/pinion on the plastic cups.
My Sledge I had to shim the diffs to get the gear mesh tighter. I wonder what the difference between our trucks is. I ran the whole thing as a set, Vitavon gears, cases, and gearboxes. Everything fit perfectly.
For us, the cost is the same between helical and straight cut gears.
Just curious... Has Tekno ever tested spiral cut diff ring/pinion gears in a EB/NB/ET/NT48 platform?
I know some companies, like Associated and their RC8 lineup, have gone back to straight cut gears after the RC8.2 was discontinued. I never really dug/searched into it as to why it was done.
We have tested spiral cut gears and quite simply they're not as durable as straight cut. With any ring and pinion gear, you're always going to have a drive side and a coast side. Since we're not going to make specific front and rear cut gears, we're always going to be driving either the front or the rear on the coast side. Now, this itself isn't a huge problem although it's still not ideal, full size 4wd trucks do this. The difference is that our cars brake through the ring and pinions, full size cars brake at the wheel. Applying brakes puts a huge amount of stress through the gears, and if you're applying the brake on the coast side, it's harder for the gears to take that stress. Additionally, setting mesh is easier on straight cut gears. They can also be set a little tighter or a little looser without as much consequence.
The only reason I might want to run spiral is if we used hypoid gears to offset the pinion up or down.
Quality control, and that's sort of my point..
Probably going to try their MT48 universal driveshafts though, we'll see how that goes..
The driveshafts are on my list too. First I think I'm going to try ditching the shock boots and install travel limiters on the shafts instead. I suspect my bent driveshaft issue is the shaft being pushed past its maximum cup exit angle. I did the same thing on my Kraton and I don't break drive cups or bend driveshafts anymore. It's all theory till you plug the battery in. We'll see.
IMHO, if I owned a MT48 2.0, I'd stick with the stock gears. Before I state my hypothesis, let me first make a disclaimer that I am not an engineer by trade and have no insight into the manufacturing process for either Tekno or Vitavon.
That said, having built dozens of custom high-end trucks that use parts from Tekno (obviously), M2C, Vitavon, Scorched Parts, and other manufacturers, I have noticed that Vitavon isn't ranked #1 based on their quality/ manufacturing tolerances.
That's not to say that Vitavon doesn't offer good products or that they have poor manufacturing tolerances, but rather, comparatively, competitors such as Scorched Parts and M2C Racing make higher-quality parts, both from a design and a manufacturing tolerances perspective.
From what I've come to know about manufacturing gears the process requires quite a bit of precision—and having dropped ~five figures worth of "bones" on Vitavon across multiple vehicles/ platforms/ product types, I haven't experienced that "wow" factor when it comes to precision.
When a company like Vitavon CNC-machines a ring gear out of raw steel, it might be perfectly flat and true. However, to make it durable enough, they must heat-treat (harden) the steel. Heating steel to extreme temperatures and quenching it inherently causes the metal to shrink, warp, and distort.
In full-scale automotive manufacturing, gears are CNC machined, heat-treated, and then put through a final process called precision grinding, where a robotic grinding wheel shaves off the microscopic warps caused by the hardening process to restore perfect GD&T tolerances. Because precision post-hardening grinding is incredibly expensive, many RC aftermarket manufacturers skip it. You are left with a gear that is incredibly hard, but suffers from heat-warped axial runout (high spots on the gears).
While Tekno RC keeps their exact proprietary manufacturing steps closely guarded, their consistent lack of axial runout (high spots) comes down to a combination of superior material selection, precise hobbing, and controlled heat treatment, rather than post-hardening precision grinding.
High-Grade Materials (Minimal Distortion)​
The amount a gear warps during heat treatment depends heavily on the specific alloy of steel being used. Cheaper alloys expand and distort wildly when quenched. Tekno uses high-grade, aerospace-quality steel alloys specifically chosen for their dimensional stability. When these alloys are heat-treated, they experience minimal microscopic distortion, meaning they retain their CNC-machined flatness without needing an expensive post-grinding phase.
Advanced Gear Hobbing​
Tekno RC doesn't just cut gears; they use advanced gear hobbing machines. Hobbing is a continuous cutting process that generates a near-perfect involute tooth profile. If a manufacturer uses a cheaper milling process or a worn hobbing tool, the teeth themselves will have slight variations in thickness or pitch. Tekno's tooling tolerances are exceptionally tight, meaning every tooth engages the pinion exactly the same way.
The "Lapped" Feel​
While they likely do not precision-grind their standard gears (as that would make a $30 ring gear cost $150), high-end manufacturers sometimes use a process akin to lapping. Lapping involves running the ring and pinion gears together with a mild abrasive compound before they leave the factory. This process wears down any microscopic high spots left over from heat treatment, ensuring the gear set is perfectly mated to itself.
Tekno's products are also made in Taiwan, whereas, Vitavon's parts are made in China. While products made in Taiwan are typically more expensive to manufacturer, they are also typically higher quality. This also may explain why I have found that both Tekno and Traxxas hardened CNC gears are typically high quality with respect to tolerances.
That all said, if the OEM doesn't offer a high-quality, durable CNC hardened gear or driveshaft, I will buy the Vitavon upgrade all day long (i.e., I have the full set of hardened #45 steel gears and driveshafts on both my Losi Baja Rey 2.0 and Losi Lasernut).
Just my 2 cents... no idea if any of the assumptions I've made with regard to Tekno or Vitavon's manufacturing processes are true, or not, but I suppose a Tekno engineer can weigh in on that if they'd like to share some of the details relative to their process for manufacturing high-quality gears.
Again, I'm not an engineer. Just sharing my experience as a fellow hobbyist customer, like you, and also, speculation as to why Tekno's gears are higher quality than that of Vitavon's.
While I own every other Tekno platform/ model, I bought the "OG" MT410 and it's fully decked out with parts from M2C Racing, AllRacing, MMM (r.i.p), T-Bone Racing (r.i.p.), etc., and don't have the urge to buy the MT48 2.0. I can't say the same for just having "one" custom SCT48, as I just bought a "roller" from one of the SCT48 FB group members.
The gears are only compatible with Vitavon gearboxes. To run them with any other gearbox the shoulder on the outside needs to be ground. It makes hard contact with the inside of the cover where the lower mounting screws go through.
I see ADU makes ring gears for the MT48 that are compatible with all brands of gearboxes including stock.
