Chozwoz
I set my ride height today at 29mm in the rear and 27mm in the front. I set the droop screws so that the lower arms barely drop at all when lifting the chassis. This just doesn't seem right as shouldn't the suspension droop a bit itself when off the ground? How do I correctly set this? Thanks for your help!
P.S. I also noticed I had to crank down the shock collars waaaay down to achieve those numbers. Is this normal? I notice my springs have quite a lot of winds in them vs everybody elses, I think they are referred to as "Low Frequency" springs? What are these?
