Anyone running the bigger Max6 with a longer can motor in their MT410? I have the wide game changer chassis so space is not an issue. For those that are, what motor/pinion do you recommend for the max6 setup?
Did you ever try it? I am thinking on getting the widened chassis and moving the esc to get the bigger motor with the 1650kv motor and a 19 tooth pinion. I think that'll work well.Anyone running the bigger Max6 with a longer can motor in their MT410? I have the wide game changer chassis so space is not an issue. For those that are, what motor/pinion do you recommend for the max6 setup?
