One thing I forgot, will the tekno motor mount fit ?Yes, you'll probably need a 20+ pinion for the proper gear mesh.
thanks for the help mate!As long as that motor has the normal 25mm screw hole spacing. If it has M4 threads, you'll need the motor mount insert from the ET48.3.
Looked everywhere but did not find the old mount with m4 I think I will buy the jqracing you sent and hope for the bestUnfortunately, Tekno discontinued the M4/M3 motor mount insert (TKR5211) at least being sold separately. However, you can still get them from the ET48.3 kit. I don't see any now but you can find them on ebay from time to time. The new insert (TKR5211X) is M3 only. I have no idea if this would work but the JQ insert looks almost identical to the Tekno. https://www.amainhobbies.com/jqracing-motor-mount-jqp-jqe0099/p260126
