I am set up with a Tekin 4300 4 pole and have a 2S battery, 44 spur and 17 pinion. Running on a dirt oval. Fast but need more speed. Have a new 3S battery and considering running in in this 410.3. What gearing set should i use?
How do like my "jow?"That's a tough question. Depends mainly on temps. Do you know jow hot it gets now?
I completed 3 4 minute runs with the 3S battery fully charged. The data as follows:How do like my "jow?"
"How..."
Thanks for your input. Have fun racing this year.Don't let it get any hotter than now. You might take off a tooth or two on the pinion to be safe, or retard the timing a little.
Retarding the timing will usually reduce the temperature, but will always comprise your power a bit.
Taking a tooth off the pinion will make it feel snappier but lose a little top speed. But will almost always reduce temps for sure.
Leaving it like it is, keep a close eye on things. And remember an increase in tire size, increase in traction such as a session on carpet vs loose dirt, can send your temps into the red.
