Shock rod ends?
HulkRC
The stock Tekno shock rod ends break easily on my MT48 2.0. Is there a more durable alternative available?
I sure hope the composite was not changed going from TKR6140C to the new TKR6140D rod ends.
How did the rod end break? I can't see one breaking just from normal suspension travel.
How many have you broken?
What length of rod end was used?
Sorry. It's a bit funny to me, 'cause I've seen Arrma Kraton dudes swapping in Tekno shock rod ends for their breakages. 🤷‍♂️😅👍
Advice from a big air addict.
Set your droop so you have to compress your shocks 2mm to install them. This won't stop your shock ends from breaking but it will make it a rare occurrence.
Broke from mediocre 10' landings. I've broken 4 and used both long and short. Ordered TKR6140D, will use the short ones, and adjust my droop as suggested by RC-Steve.
I have done both and they still break. But from bigger jumps though.
The shock rod end is a cheap weak point engineered to break instead bending the shock shafts, body, etc.
