Front wheel wobble at high speed
Gjflores
Hello everyone, I hope you can help me. I just put together my first tekno et48.3. My problem is at high speed my front wheels wobble. How do I fix this?
Wheels run fine on my Kraton and wheel nuts are tight
  • Like
Reactions: SrC
Balance the wheels. I always do regardless. It is always part of any of my builds. And I would put a different set on the ET first. Take it from there. We have to assume the ET is built correctly. Are the hubs and bearings snug at the front. Any undue slop with camber rods. You said it is a fresh build? Did you ream the arms for the inner and outer hinge pins at the A block and B block? Did you over ream any? You said it is fine on the Kraton with a pillow ball hub, and no good with the ET that uses a camber link hub design.
Balance the wheels first. Inexpensive balancer and clay.
