Droop and ride hight on a bumpy, loamy & blown track
Kozzy
Hello,
What would be the generally recommended settings for the droop and ride hight on a bumpy, loamy & blown track?
I'm heading to a race this Friday with Box Setup, but will probably need to make some changes.
Temp is ~20C ( ~68F )
If someone can also share a Setup sheet what will be great.
Is this for the NB48 2.2? If so the box setup is built to handle well on rough tracks. If the temperature is around what you stated or less be prepared to drop shock oil by 50-100cst.
Yes 2.2
The changes I made are:
1. 450 cst front
2. 550 cst rear
3. 78mm Front springs
4. 73mm Rear springs
Other than that it's Box setup.
Thanks
