410 2.0 Dogbones falling out on mt410 2.0
tonywetfur
During assembly i think i screwed my droop screws all the way in. After my dogbones fell out twice at the skate park, i moved the droop screws to about midway. Today i bashed on a ramp in grass and my rear dogbone popped out again. Google says the best fix is shock limiters but i dont really wanna take my shocks apart and then throw washers or fuel tubing in there. Google also said to move around shock positions and shorten camber links. Has anyone had this problem? Howd you fix it?
Yes, I had the same issue, and spacers fixed it. The techno dealer here recommended using the plastic washer type shock spacers, rather than using fuel tubing as it flexes and could still pop-out.
A bit of a pain re-filling the shocks but doesn't really take that long and a lot less annoying than it popping out! And I imagine trying to do it with shock positions will impact handling in other ways.
The driveshaft exit angle from the drive cup is a lot more extreme on full compression than on full extension. Maybe travel limiters on the shock shaft in between the ball end and the body would help. Limiting compression by 3-4mm would probably do it.
