EB48SL Rally Conversion - Extended Body Posts Recommendation Needed
EB48SL
I am looking to convert my EB48SL into a rally car. In preparation for the conversion, I purchased the following items -
  1. Proline Avenger Pre-mounts Tires/Wheels
  2. Delta Plastics Lancia Rally Body
  3. Tekno Narrow 17mm hubs
  4. Tekno SCT410.3 Body Mounts
The body looks like it will need longer body posts to mount the body and clear the wheels. Proline discontinued the extended body mounts for the SCT410 Proline part # PL6272-00. Do any of you of any other extended body mounts that will work for my application? Thank you in advance!
I was able to make the Delta plastics WRX body work using the stock body posts. I think they are extended almost as far as they can be on the rear but it works. Obviously not the same body but just throwing this out as an example while still using the stock body posts.
Thank you TBuggy, PrimaRC, and Nicochau for the helpful links and recommendations. Truly appreciate all of your helpful advice for my Rally Project. Trying to build something unique.
EB48SL rally conversion, consider extended body posts from reputable brands like Pro-Line or JConcepts. Look for posts that offer durability, easy installation, and compatibility with your specific model. These upgrades can enhance both aesthetics and performance on the rally track.
