Desert Buggy conversion?
MAC FAB
What is the desireable cage(s) to make a DB and why? How much cutting and hacking is needed to make this happen? Which vehicle model are you putting it on?
team associated nomad caged works the best mounted on et48.3 chassis with eb48 shock towers
here is front look
Team associated nomad very easy to make work
Mt410 bracket rear tower
Here is a cage. I done up with eb48 shock tower this cage is forsale
What chassis are you using on that?
I’d like to build two Desert Buggy’s
1. SCT To DB build using ET chassis
2. MT to DB build using ET chassis
Anyone considered the new Losi Lasernut cage? Looks like it work as well.
Went to look at one that has been setting for years. Tube frame sand rail type. Would need to go through everything: brakes, fuel lines, lot of cleanup, etc. Mostly stock VW. How many of you guys own them. Do you use them much. Fun factor looks high. Actually has a title for on road use.
