Tekno ET48.3 Power Hungry
Overkill
Birmingham, AL
EB48, ET48
M2C wide truggy chassis
I countersunk 6 holes to create a different layout. 3 for the ESC plate, 2 for the receiver box, and 1 for the wire guide.
Tekno wire guide (TKR4106)
Tekno EB48 2.0 stand-alone receiver box (TKR9065)
M2C ESC plate rotated 90* and moved further inward, I love the versatility of this plate.
Kydex 2mm sheet for the battery supports, then shaped with a heat gun.
All Racing 7075 gearbox. These use much larger 5x15x5 pinion bearings, which is a major plus for big power builds like this.
Losi HD center diff case with 40T Fly Ratio spur gear.
Proline Badlands 5.85"
Belted with vectran braid (stronger than Kevlar)
Cordova 1440 (40x102mm) 2000kv. This motor is absolutely amazing, it makes a ton of power and runs ice cold regardless of gearing. I'm currently running 24/40 gearing.
Castle MMX 8S. Castle did a really great job with the design of this ESC.
TPP 40mm aluminum case fan. The stock plastic fan broke very quickly.
OSE 8mm anti-spark connectors
Proline thumbwasher kit
Turnigy Graphene V2 6S 5000mah
Servo turned around, along with a hole for the wire exit, for the M2C wide chassis.
M2C 7075 center chassis brace
Exotek steering assembly. The stock one works great, just wanted to try it.
O-ring for a rear motor support
40mm ID, 6mm width
I like the ESC positioned here much better.
Overkill
Birmingham, AL
EB48, ET48
Fan wires go through this Tekno wire guide, attached to the M2C 7075 center to rear chassis brace.
Aluminum case fan is a direct fit, much better than stock and it stays running the whole time.
Leadfinger NT48.3 body
smirkracing
EB410, EB48, ET48
Looks absolutely insane!!
I didn't catch what the 6 new holes you drilled in the chassis allowed you to do.
Can't wait to see the vids.
Have you tried the new belted Badlands? I wonder if they'd hold up to that motor.
Overkill
Birmingham, AL
EB48, ET48
Thanks. The ESC plate is mounted to the chassis with 3 screws, so the design allows you to move it wherever you want. I turned the ESC plate 90* and moved it further inward. I shaved off the stock receiver box and mounted the EB48 2.0 stand-alone receiver box on the other side with 2 screws. The last hole I made was for the wire guide, for the servo and ESC wires.
I like that Proline is making belted tires but my method is stronger and lighter. My belting process can handle extreme power without breaking, even with the front tires in the air trying to unload. It also weighs virtually nothing. I really love the original Badlands, they’re my favorite tire for traction and being light weight.
This picture shows the standard layout.
This is low speed part throttle driving. This truggy is an absolute monster, it’s hard to stay on the ground. It will flip over backwards easily from a roll.
@Overkill How are those allracing gearbox cases when it comes to inserting the diffs and diff shims?
I find with the plastic stock ones can be tricky to get the diff shim to sit properly into the groovesf or the output bearings without bending the shims.
I do try to shave angled channels into the cases by using an x-acto knife but it doesn't always work.
Overkill
Birmingham, AL
EB48, ET48
They're the same as stock in that regard and I didn't use any shims on this one. I honestly can't remember the last time I've needed to use a shim with the Tekno gearboxes, they're that good. If you're having trouble, you can try spreading a very thin layer of grease on the shim so it sticks to the bearing during insertion.
smirkracing
EB410, EB48, ET48
Overkill, those are fun vids. Only partial throttle? Would love to see full speed. Do you have a GPS? I am keen to know what the top speed is.
I have some belted badlands which I am going to put to the test soon.
Overkill
Birmingham, AL
EB48, ET48
Yup, it requires a huge open field to stretch her legs out and even then it's still difficult to keep the front end down. I would need to use smaller tires or a custom wheelie bar to keep it on the ground, or have access to a long fairway on a 5 par hole lol. I do have a GPS but the last time I tried it, it was having issues. Good luck (y)
nulli
Finland
Kudos. If you have the skyrc 4 point scale or similar you might want to check the mass balance, just in case.
Kronuxx
California
SCT410
Sweet build man. Just wondering why are you using the losi HD diff? Also, although I think the All racing gearboxes look cool, I'm not a fan of adding more weight than needed. That's more kinetic energy expended somewhere when you crash, hard turn, etc. Big reason why the Arrma speed chassis are becoming more popular than their heavier weight 4 mm counter parts, since they hold up just as well in a bash session.
Overkill
Birmingham, AL
EB48, ET48
Thanks. I use the Losi case because the Fly Ratio 40T and 35T spurs fit it, I like power. :) The All Racing gearbox is very important to this build. The larger pinion bearings make a big difference in durability when you’re pushing this amount of power. The weight difference isn’t that much with the aluminum gearbox, having light tires makes the biggest difference.
I always found that going by the build manual and using a shim each side 0.2mm? Ensures a good mesh between the diff pion and ring gear.
Only problem is they often don’t quite sit into the channels when piecing the two gearbox halves together and then splay out and get bent.
smirkracing
EB410, EB48, ET48
Overkill what diff oils are you running f/c/r?
Thanks!
Overkill
Birmingham, AL
EB48, ET48
The shims are optional, not required. I haven't had a need for them in a very long time. They can be delicate, you just have to take your time.
Thanks!
60k, front
1m, center
30k, rear
Looping67 48.3 My first ET48.3...and first Tekno as well. ET48 4
R New Tekno ET48.3, getting ready to order everything ET48 11
C 48.3 My first Tekno ET48.3 :) ET48 12
Slevin 48.3 Slevin’s Tekno ET48.3 Build RC Builds 252
WoodiE LFR Strife body for Tekno ET48 coming soon ET48 18
WoodiE Most Recommended Tekno ET48 Upgrades ET48 25
Tankd72 48.3 Tankd72's Tekno ET48.3 RC Builds 12
WoodiE Tekno RC ET48.3 Manual & Setup Sheet ET48 1
harlon M2c zrs shocks caps or tekno emulsion caps.🤔 MT410 5
Ifti 48 2.0 Tekno EB48 2.0 Complete Video Build Guide! EB48 24
S 48.4 First Tekno kit. EB48.4 EB48 3
Will Best Tekno Corona/Christmas ever! EB410 1
G Tekno tools Tools 3
ReMiXeDg M2c or tekno brand for differentials MT410 6
cAn”t DrIv3 4 sH!t cOol I’d like to phone a tekno dude EB410 8
harlon Hello tekno forum 😀👊 MT410 12
cAn”t DrIv3 4 sH!t cOol tekno Eb410 EB410 4
Sludog New Tekno Nitro coming??? NT-48 6
J Tekno mt 410 diffs MT410 6
Sludog Tekno RC has the EB 48 2.0 in stock, but limited EB48 3
Woodysaw My Tekno MT410 build MT410 13
Barney Servo saver on Tekno EB-410 EB410 2
WoodiE New Tekno NB48 2.0 aluminum throttle servo horns NB-48 0
H What Tekno DB to build? RC Builds 5
GeekedupFL Howdy , first Tekno , looking for esc/motor suggestions ET410 3
lampshade9909 Authentic looking Monster Truck tires on a Tekno (Brainstorming) RC Builds 41
WoodiE Tekno EB410.2 4WD Buggy has been announced! EB410 9
D Trail Tekno? Paint and Body 9
Justin1975 1st Tekno build was a dream! Now which one is next? MT410 7
Relic01 Are people putting 6s LiPo in the Tekno MT410? MT410 29
P Has anyone ever used Traxxas ID lipos in their Tekno mt410 MT410 7
S Cleaned up my Crawler (Not Tekno, sorry haha) RC Builds 4
M Tekno MT48.3 - Truggy chassis converted Monster Truck MT410 29
Drew New to the tekno forums so sorry if i ask something thats already been asked! Sct410 to nitro????? SCT410 6
Budki Tekno sct410.3 Build RC Builds 49
WoodiE Tekno Hardened Steel Diff Case Chassis & Drivetrain 4
S New to the Tekno scene. EB410 5
mattbhm My first Tekno, complete. MT410 5
L tekno eb48sl EB48 2
Klappars Tekno 1/8 drivetrain durability/wear rate compared to Arrma ET48 23
matimath Rumors of a Tekno EB48.5 EB48 22
Eric Fan TW Tekno MT410 nitro... MT410 4
Jmill102980 New to Tekno first Tekno build was a great build still finishing up. MT410 10
Brandon Rock and Roll Tekno Paint and Body 4
F New to the tekno brand!! MT410 9
WoodiE Tekno Shock Standoffs Chassis & Drivetrain 1
WoodiE Tekno Carbon Fiber Receiver Tray Chassis & Drivetrain 2
WoodiE Heavy Duty Differential Outdrives & Coupler for Tekno EB/ET 410 Chassis & Drivetrain 4
StevieGT Crash test dummy with Tekno ET48 5
S Updated Tekno garage... RC Builds 4
