For Sale Tekno/Arrma CVD Driveshaft kits
Scotty510
I have the retainer rings in stock.
https://www.ebay.com/itm/173960669303
Arrma 5mm steel CVD Driveshaft kits for the Tekno ET48.3 and MT410! The full kit will include everything shown below and is 100% bolt-on. Everything in this kit has been thoroughly tested for months. Each part has been selected for a quality fitment and function. I would recommend using the updated TKR8727 shock standoffs on the front, they are slightly longer which will give you more clearance from the driveshaft rubbing on the spring.
These are the Arrma part numbers used, in both a set or individually. They are used only on the front of the Talion, the rears are not CVD’s. The Kraton/Outcast use different stub axles than the Talion but the driveshafts are the same.
AR220031, Driveshaft & Stub Axle
AR310458, Driveshaft
AR310487, Stub Axle
AR310452, Barrell & Pin
These are the rest of the parts used.
600223, Serpent Wheel Hex
110212, Serpent Pin 2.5x17mm
Custom Steel Ring (Please contact me if you need some)
Steel Shim 8x14x2mm (A small percentage need a 1.5mm thick shim)
Knurled Set Screw M5x5mm
SOLD OUT
The full kit is $120 shipped.
This is the partial kit and includes everything needed for installation, minus the Arrma driveshaft and stub axle.
SOLD OUT
The partial kit is $45 shipped.
How can I get my hands on this kit? I’m going all out and want to build this mt410 right for bashing
Overkill
Birmingham, AL
All of the parts are readily available online except the retainer rings which I sell.
mwkatm
I am having a hard time tracking down the shims, can you share where you sourced those? Thank you.
tbrewer187
Would like to know if your going to be selling the full kits again. If not would like the info on purchasing the retainer rings. Thanks and awesome mod!
Overkill
Birmingham, AL
The shims are available from McMaster, get both.
8x14x2
98089A441
8x14x1.5
98089A119
@Overkill
Will you be getting these kits back in stock anytime soon?
I only sell the retainer rings.
I only sell the retainer rings. I’m out of stock right now but will have more later this week.
jron
Anyone know how to get these rings? I've reached out to Overkill but haven't gotten a reply. Thanks!
