For Sale Tekno/Arrma CVD Driveshaft kits
Overkill
Birmingham, AL
I have the retainer rings in stock.
https://www.ebay.com/itm/173960669303
Arrma 5mm steel CVD Driveshaft kits for the Tekno ET48.3 and MT410! The full kit will include everything shown below and is 100% bolt-on. Everything in this kit has been thoroughly tested for months. Each part has been selected for a quality fitment and function. I would recommend using the updated TKR8727 shock standoffs on the front, they are slightly longer which will give you more clearance from the driveshaft rubbing on the spring.
These are the Arrma part numbers used, in both a set or individually. They are used only on the front of the Talion, the rears are not CVD’s. The Kraton/Outcast use different stub axles than the Talion but the driveshafts are the same.
AR220031, Driveshaft & Stub Axle
AR310458, Driveshaft
AR310487, Stub Axle
AR310452, Barrell & Pin
These are the rest of the parts used.
600223, Serpent Wheel Hex
110212, Serpent Pin 2.5x17mm
Custom Steel Ring (Please contact me if you need some)
Steel Shim 8x14x2mm (A small percentage need a 1.5mm thick shim)
Knurled Set Screw M5x5mm
SOLD OUT
The full kit is $120 shipped.
This is the partial kit and includes everything needed for installation, minus the Arrma driveshaft and stub axle.
SOLD OUT
The partial kit is $45 shipped.
sniper34
I need the parts in the second pic. I have the axles. Been waiting for that kit from you for a few months. If it's going to be a while yet, could you give me info on part numbers or what Arrma vehicle they came from? Driveshaft too please. You can pm here ..
Overkill
Birmingham, AL
I’m waiting for the wheel hexes to arrive. I ordered directly from the manufacturer that makes them and its taking a little longer than other methods. They are very high quality and not made by Arrma. They have shipped out and I’m hoping for about a week from now. I’ve updated the post with the Arrma driveshaft part numbers.
sniper34
Are the ones that are ready to ship monday the better non Arrma ones you were waiting for? And do they come with the whole 45$ kit?
Overkill
Birmingham, AL
Thanks for your orders guys! These will make your Tekno even more bulletproof. (y)
3literheater
Do you have anymore of the $45 kit?
