I have the same issue I think. Do you mean the front wheels aren't perfectly straight across from each other? Like one it in the straight across middle and the other is slightly off? Should be just a simple turnbuckle adjustment I hope. No sure if I should do it now or wait until I hook up the steering servo.I fixed it seem like I didnt tighten the screws the right way. Now the issue im issue I'm having is with the front wheel alignment. Anyone know what's the size the turnbuckles suppose to be.
It's mentioned in the build manual, make sure to set the using calipers so they are accurateYea I believe it's the turn buckles need adjustment
