Silly rebuild question...
Sscheitel
Long Island, NY
Rebuilding MT410 from scratch after running through a mud puddle over a year ago...
My question is about part# TKR5430 suspension arms....the screw that goes through the suspension arm to hold the sway bar mount in place doesnt tighten up. Is this normal? Can this stay like that? Is there a trick to getting this to tighten in place?
If it gives problems you can simply replace the arms.
I usually don't tighten those screws very tight anyways. Neither the one holding the shocks in the arms. I used to and the rod ends would end up cutting into the arm. Now I choose to let the rod end beat the threads off the bolt.
