Loyd
I'm having trouble with motor mount/insert/motor and need some guidance (Castle 1412, it's 36mm). With the kit supplied insert used in the pictures the motor assembly does not slide nicely into the mount. Red lines in picture show where there is contact, I believe because the motor is not flush or is proud of the insert and scrapes the mount...you can see the scrapes on the mount.
I found this thread https://www.teknoforums.com/threads/4274-motor-mount-insert-problems.2056/ .....issue is different. Motor is hitting his CHASSIS because it's 42mm. But his picture with motor and insert looks similar to mine and I assume slides nicely before hitting the chassis.....mine binds before getting close to chassis.
I think I am mounting the insert to the motor incorrectly and need some help. Thanks and Happy New Year!
