Recommend a battery and a charger for me?
Clodbusterfan
Can anyone recommend a 2s shorty lipo battery for my eb410 and the cheapest charger out there thats not junk. This will be my only lipo vehicle for awhile so dont want to spend much on the charger. I want long run times with my battery most of all! Thanks guys!
WoodiE
Kind of good admin
Staff member
Kentucky
@Clodbusterfan I use the following setup and would highly recommend it. It will easily charge your 2s LiPo and pretty much any other LiPo battery you throw at it with plenty of power to charge more.
Charger: iSDT Q6 Plus
Power supply: HP 24v 1000watt
The iCharger X6 is also a nice charger and I know @Billl DeLong is a big fan of it. You'll need to get an external power supply for it as well, just like the iSDT Q6.
If you're wanting something that's more of an all-in-one solution than it might be worth checking out the Venom Pro Duo or the Hitech RDX1 - just note these are smaller, less powerful chargers compared to the two mentioned above. So if you do have any intentions of charger larger 4s / 6s LiPo batteries your charge time is going to be much longer.
I personally would go the iSDT or iCharger route.
Something to consider about the iSDT Q6 is that it is limited to 9A of input current where the iCharger X6 can support up to 35A of input current.
That means you will need to invest in a more expensive 24V supply in order to get the full 300W potential from the Q6, where you can use a less expensive 12V supply on the X6 and still get 35A x 12V = 420W of power with that charger with a 12V supply.
Also note that the X6 offers a balance current of 2.0A where the Q6 offers only 0.5A of balance current, this will allow the X6 to balance the cells 4 times faster in the CCCV cycle which can be the difference between a 10 min charge with the X6 and a 30 min charge with the Q6 with an older pack, with both chargers initially set to the same charge rate... the balance current is key for quick and reliable charge times ;)
Use these features to compare between chargers so you can compare apples to apples so you know what you're getting.
Clodbusterfan
I dont need a fast charger since I wont be racing. Its ok if it even takes a couple hours. Which one would you recommmend now that you have that info?
If time spent on balancing cells isn't important and you only need to charge at 1C, then the Q6 sounds like a logical option simply because it's only $30 which is one of the least expensive chargers I have seen which offers an IR meter which I feel is the single most important feature to have on any charger. That said for 1C charge rates, you can also get away with a less expensive 12V supply as well ;)
12V x 9A = 108W max supported by the Q6
108W / 8.4V = 12A max charge rate you can use with a 12V supply which is roughly 2C charge rate for a 6Ah pack
Since the max balance current is 0.5A you should expect charge times around 30min @ 2C when the pack is new, but as the IR fades over time, your charge times will grow exponentially longer, upwards to 45min to an hour to charge the same pack at the same 12A charge rate.
Nicochau Would you recommend EB48 “.1” to a friend? EB48 1
MikeBuzz Recommend me a motor SCT410 4
Illestep3 What motor/ESC combo do you recommend? Electronics 43
Steve B in Vegas Trinity Graphine LiHV battery Electronics 6
Ifti Battery settings.... Electronics 7
MAVERICK Chang pinion size or battery size EB48 3
BashingBrian What mAh battery MT410 4
BashingBrian MT410 what Battery power.?? MT410 4
Ifti 48 2.0 Battery Tray Size EB48 23
Tekno4Life battery combantions??? MT410 2
Famous481 Battery straps Electronics 9
Synthesis Questions about battery run time with this setup on MT410 MT410 6
Cody's mt410 Choosing a 6s battery with traxxas connectors MT410 1
C PowerHobby Battery Input Electronics 2
Overkill Soft case battery protection Electronics 4
S 6s Battery? Not finding one I like... ET48 10
T Anyone using a Turnigy Panther 6S battery? MT410 2
keoni068 Big Battery Options MT410 6
Slogrits Best battery connector Electronics 23
cadon78 48.3 Battery strap rubbing center front drive shaft. ET48 12
Slogrits Bad battery day Electronics 8
N 48.4 Issue with battery strap tearing? EB48 4
Motorider Battery test page Electronics 1
TooTall Anyone know of any Battery Tray mods or aftermarket trays? MT410 2
T What is your battery charger of choice? Electronics 95
WoodiE What is your LiPo battery of choice? Electronics 78
SHWA Best Charger Options for 6S 5000mah batteries Electronics 24
E 6S Lipo brand and suitable charger Electronics 14
cdaxj Spektrum smart charger s2100 Electronics 3
