Questions and links re new MT410 build
NicC
Hi everyone, I've been gathering information for my new build.
My goal is to order everything and build a fast basher. Speed is as important to me as a strong, premium build.
I have the following questions, followed by the links and recommended parts from various users which I've gathered.
I'd appreciate any feedback.
  1. The Max8s appear to be the most popular ESC. Does this handle 4s or 6s? or both?
  2. A variety of servos work but you must get the aluminum servo horn, correct?
  3. I didn't see anything specific re 6s batteries. I'd like this thing to fly so does a 6s battery fit in this to start? 2 x 3s? or start with 4s?
  4. I've had an number of pinions recommended. As long as the internal diameter fits the motor shaft (obviously), then does the mounting setup allow you to adjust so your pinion meshes correctly with the remaining stock gearing?
  5. Which pinion is going to give me the most power, without destroying something?
  6. Are any extra tools required for assembly? I have all the usual, excluding shock pliers (buying) and an impact drill (I have an electric driver). Otherwise I am set.
  7. I didn't see much re receivers. I have a basic Flysky FS-GT5 with no gyro. Is this okay https://www.amazon.com/Flysky-FS-GT5-Transmitter-FS-BS6-Receiver/dp/B07B2SVQ3M
  8. Is there anything else I must order now so that I don't sit here twiddling my thumbs waiting for parts?
Thank you so much!
Nick V
Servo = protek 170tbl or two below
https://www.amainhobbies.com/protek...oDtrMpjktHyRRbDRUQzVnQOVZSkkRLoBoCFRAQAvD_BwE
or
https://www.amainhobbies.com/mks-se...qSHoEwGVc2ASMNqhGwwf6rLkzHeMY2uRoCU-wQAvD_BwE
or
https://www.savoxusa.com/products/savsb2290sg-monster-torque-black-edition
Tan Y
ESC = Hobbywing EZRun Max8 V3
https://www.amainhobbies.com/hobbyw...KObmO93o1LI8pJ_lkTBBEKUrigZjRvGhoCgKsQAvD_BwE
Motor = 1600-1800kv Surpass
https://surpassracing.com/product/surpass-rocket-v4s-17-5-stock-spec-racing-motor/
Jean-Francois B
Motor + ESC = Hobbywing max8 2200kv Combo
https://www.amainhobbies.com/hobbyw...mSsKxsmKBMK4j3UflreXK38I_3SmhgnhoCepUQAvD_BwE
Servo = SV1270
https://www.amainhobbies.com/savox-...7J4N2BcPRFdxcheXV8PMCdFY4kOwOyPRoCBr0QAvD_BwE
Receiver = Radiolink
Tyres = backflip LP tires.
https://www.towerhobbies.com/produc...fnqLPjqO3H3uqyWytKmHjubD07k95-bBoClKQQAvD_BwE
Patrick O
ESC = EZRun Max8
https://www.amainhobbies.com/hobbyw...au0nPTojZQ6AEXKNUL4D5eDvunkzzKChoC-TIQAvD_BwE
Pinon = 18T
https://www.amazon.com/Traxxas-Hardened-Steel-Pinion-metric/dp/B0027L9H5E
Servo = JX Ecoboost
https://www.amazon.com/Ecoboost-CLS6336HV-180Degree-DigitalCoreless-Helicopter/dp/B07NMTGJCY
Paul J
Pinion 19t
1600 to 1900 KV Motor.
2200 kv with 18t = "bonkers fast"
Mich Rv
Motor / ESC combo = EZ Run 220Kv
https://www.amazon.com/38010401-Combo-EzRun-2200kV-Motor/dp/B01I2CALYM
Servo = Nitropro
https://www.ebay.com/i/223937503196?chn=ps
Server Horn = Tekno
https://www.towerhobbies.com/produc..._kbU_C7LayEgtdIsC4_ZCs9IGzZnmjuxoCC4wQAvD_BwE
Tyres = these belted ones
https://www.arrmaforum.com/threads/new-proline-trencher-belted-hp-3-8.14931/
Jason T
Motor / ESC = Tekin RX8
https://www.horizonhobby.com/produc...PbAnnC5T9eQfs0N78hxv0qjbFW0S9DNhoCjK8QAvD_BwE
Pinion = 16 tooth
Servo = https://www.amainhobbies.com/protek...jMlIzYozEQ-Zu35ogRp9ta2Ox94LA-ZBoCn2oQAvD_BwE
Thomas W
Motor = Tenshock
https://www.ebay.com/c/1839099869
Servo = Amewi Standard
https://www.conrad.com/p/amewi-stan...ox-material-metal-connector-system-jr-1953729
Ryan G
Motor / ESC = Max 8 Combo
https://www.amainhobbies.com/hobbyw...NfFFMo_z7MNPyGQLK-gFWNSHYJwxXObhoCWvoQAvD_BwE
Battery = Zeee 4s
https://www.amazon.com/Zeee-6500mAh-Battery-Connector-Vehicles/dp/B07PLSYL4K
Amateurhour
Welcome! I look forward to seeing the build, don’t shy away from posting pictures 👍
I’ll take as shot at answering questions:
1) The max 8 is capable of both 4 and 6s
2) Correct, just get a horn with the matching spline count to the servo that you choose.
3) The truck is 6s capable and will definitely fly on 6s. Its a bit unruly but it definitely moves.
4) Yep, the motor mount slides to allow a variety of pinions and spurs to properly mesh.
5) The best pinion depends on a lot but usually revolves around the largest that you can run without overheating the motor. Driving style, ambient temperature, terrain, tire size, and more all play a factor. I would definitely recommend mounting a fan and heatsink on your motor. I am happy with my yeah racing dual fans but definitely get some aluminum framed fans.
6) A small set of metric allens is all that should be needed. 1.5, 2, 2.5, and maybe 3.0
7) I don’t have any experience with flysky so I’ll have to pass on this answer.
8) Have you picked out tires and a body yet? I can’t think of anything else that you will need. Do you have soldering skills and all of the battery and motor connectors that you’ll need?
NicC
1. Thanks.
2. Thanks, got the ideal one, with 25 spline count (in below parts list)
3. Thanks, it's going to be handful.
4. Thanks, makes sense.
5. I will get fans and have since done some pinion research. I don't want to go too big.
6. I have those tools, thanks.
7. Ok.
8. I have in the below google doc. Tyres and body.
9. Soldering skills? No. Soldering equipment. Yes! What connectors will I need?
Google doc: https://docs.google.com/spreadsheets/d/134dLjtHy-zRj6XNkWSP1lkNeCpW7qoeiSuz10Zxtf48/edit?usp=sharing
Amateurhour
Haha I started the same way, tools are quick to acquire but the skills take some practice.
Usually all that you’ll need to solder is battery connectors and motor connectors. Sometimes if you pick your combos carefully you can order the ESC with the proper connectors installed from the factory. What battery connectors are you going with?
NicC
Yea. Only some videos and old habits to guide me. .. recipe for chaos.
so far for connectors all I have are adaptors. So that’s fluid...
I’m finalizing the ESC motor combo...
Nicochau
Stick with the better xt90 or EC5. Better safe than sorry.
NicC Build nearly complete. Some final questions. MT410 9
Steve B in Vegas Chassis Length Questions Chassis & Drivetrain 4
Sscheitel MT410 Build Questions MT410 38
D Newbie questions EB48 7
