New MT410 owner. Center diff heat question, Mamba X 8s and 1520 1650kv.
Lukejt
Hello all. I'm a long time RC guy here. I picked up an MT410 because I enjoy building kits. I'm running a Mamba X 8s with the 1520 1650kv and a 22 tooth pinion, steel center diff case, Backflip 4s LPs, stock diff oils and a 4S 7200mah. Performance is fantastic. Long run times, 25 minutes and plenty of power. The motor isn't getting hot, but the center diff is. I was messing around in the yard, pulling wheelies and the front wheels began to spin up causing the the truck bounce. It runs really well when it's cold.
What's the ticket for improving the center diff performance?
Also, my ESC is mounted to the rear shock tower, I need to figure out a way to get it installed lower. I've seen some of the braces and parts to allow it to be mounted over the center diff.
Luke
Matthew_Armeni
Tekno RC Staff
Tekno RC Staff
What diff oil do you have in the center? Sounds like you need to go thicker.
Lukejt
The stuff that came with the kit, 100,000 wt
sandblaster
Oregon
  3. SCT410
If front wheels are spinning too much, increase the car diff oil. That motor and gear comb most likely will need adjustment in oil. Sounds like the center diff is being pushed real hard. Look at M2C Racing for a larger center diff case. Also look at the new diff case and gears used in Tekno's newest track car. They have a new design that offers some locking diff action. The case and internals are larger than in the MT410 kit. The new setup works only in the center diff. as it is too large for front and rear diff. Had all the numbers someplace, if needed will need to spend time finding them. I installed a set in a M2C chassis build and liked the action very much. All four wheels seem to stay planted and puts the power to the ground. Like it so much will be looking at updating other Tekno builds I have. There is a thread somewhere on this.
Lukejt
Thank you!
Lukejt
I've ordered 500k diff oil and silicone ear plugs. Will experiment.
