My MT410
grizzlyadams
My first kit build. All spektrum 6s electronics & 4s copperhead tires from Jenny’s. New gensacearespammers dual charger and two Zeee 5200 4s batteries. Trx4 sport body.
Did my first soldering today in many years with a new ec5 connector to clean things up. And tried my hand at painting and masking.
Glad to join the Tekno crew.
Thanks guys. I had a lot of fun building it (maybe even a little more than bashing?!?) Waiting for things to dry up to give it a good run.
My new MT410 2.0 build!
Proline Cliffhanger pro body, clear matt finish.
Proline MX28 Badland tyres, 3s lipo Hardpack
HW Quicrun 3652SL 3250kv (14T pinion) + WP10BL 120A G2 ESC combo.
Hop-ups: chassis brace, machined CNC pistons
It's taken a hammering from my teenage boys, cracked a piston and smashed my lovely bodywork, but that's it so far!
I really like the flat black. I am assuming you painted the outside of the body. I think I'd have to paint a gray, or different color, on the inside to show through as the flat black layer gets scraped away.
How do you like that Quicrun combo?
Black inside: Tamiya Lexan Spray Paint - PS-5 Black TAM86005
Flat clear on the outside: Tamiya Lexan Spray Paint - PS-55 Flat Clear TAM86055
Quicrun combo is good value and ok but should have gone for a 3660 can size which would take 4s (the esc is up to it I think). Its a bit underpowered atm. Heat sensor has cut out a couple of times on grass with my teens at the helm, ragging it full throttle. But motors are sealed and esc water resistant 👍
We've been sending it on a home made ramp - piston wasn't cracked, the cap screw holding it on the piston rod had come undone...
