Motor choice..?
BashingBrian
UK
MT410
Would this motor "Tekin Redline T8 GEN2 4038 1550kV" be ok running on 6s, I was told it only works on 5s max..!! 🤔
Tekin list it as 5s only..!!
It's kv means it will almost certainly be ok to run on 6S, Tekin will under rate it to cover their backs and because most Tekin stuff is for racing so they expect you to run 4S most of the time and say that with 4S gearing, 5S would be the max you would want to run on it.
Also bear in mind that to get decent speed out of that motor on 6S you are going to want to gear it relatively high, due to the average size of the motor (40*77mm) it probably won't cope with too high gearing and may overeat. May be worth trying though at that price!
EBaltazar
I run this same motor in my MT410 on 6s. It's very quick and powerful. I think I have a 16 tooth pinion on it. I only have to worry about temps when ambient rises above 85 degrees or so. I'm in Louisiana and it's humid here. I can get through a 4k mAh pack usually. Most of my running is park stuff with wide-open throttle runs. No hills here, just flat spaces. 🙄
MikeBuzz DB48 ESC and Motor Choice Electronics 7
W Motor/esc combo for a newb MT410 6
cAn”t DrIv3 4 sH!t cOol Fast motor EB410 2
N 48 2.0 Motor / ESC and early upgrades EB48 9
J Will this motor / esc fit in MT410? Castle MT410 6
Sludog Anyone have photos of Arrma BLX 185 motor and ESC setup MT410 6
Sludog MT410 build kit coming, need some motor buying advice MT410 11
ReMiXeDg 48.3 best motor and esc combo ET48 2
N Best motor for 5-6s? MT410 5
lampshade9909 Best non-Tekin ESC that fits in the ET48.3 with a Tekin motor? Electronics 21
DangerD New Motor for 6s MT410 19
GeekedupFL Howdy , first Tekno , looking for esc/motor suggestions ET410 3
wjb111 EB410 motor fan EB410 4
lampshade9909 Do you guys run motor heatsink & fan or just a fan? ET48 4
E Motor/ESC limits.. ET410 3
G Motor cogging, radio the cause? ET48 8
G Metal clanking sound, motor turns, wheels barely.. ET48 16
P Waterproof motor & ESC for ET48.3 and Grass running ET48 7
P Waterproof motor & ESC for ET48.3 EB48 1
ZUMA Castle 1515 Sensored Motor, Whats A Good Motor Fan? MT410 0
S Hello, new to forum with motor esc question MT410 Electronics 11
M Fan Mount for Hobbywing 4274 Motor MT410 5
Mesfume I Can't find a Motor Fan that fits. MT410 14
Tamiyauberalles 48.4 Does anyone feel the need (and managed to fit) a fan on the motor in their buggy? EB48 7
Ballistic1 Yes another newbie - plz help with choosing Tekin esc & motor ET410 2
C Pinion size and motor temperature Chassis & Drivetrain 4
I Motor Fitment ET48 9
S New ET48 build, basher, long can motor ET48 28
Brandon motor kv question MT410 8
Slevin Picking a new motor Electronics 6
Hye 410.3 Need help picking a motor to race with. SCT410 3
1 Sct410 motor in reverse? Electronics 6
keoni068 Motor Size and Gearing Differences Electronics 1
V Mt410 esc and motor? MT410 32
Fnfancy Motor keeps breaking MT410 6
cordell12 Motor heat problems Leopard 4092 1480kv 3.5D wind Electronics 29
TIME MACHINE MT410 motor - 2 poles or 4 poles? MT410 12
cordell12 Solid Motor Leads - 4mm connector Electronics 5
thirtydaZe Motor Fan Quits Running EB410 8
MikeBuzz Recommend me a motor SCT410 4
Hye Best fan for motor? MT410 11
cordell12 48.3 et48.3 Help me choose a motor and esc ET48 46
Illestep3 What motor/ESC combo do you recommend? Electronics 43
BashingBrian MT410 pinion choice.?? Chassis & Drivetrain 9
T What is your battery charger of choice? Electronics 95
WoodiE What is your LiPo battery of choice? Electronics 78
