If you're looking for an RC that doesn't need a lot of upgrades out of the box, then the Tekno EB410 buggy is what you're looking for. Out of the box the EB410 really doesn't require any upgrades... with the exception of the plastic servo horn. However, there is always room for improvement and below is a list of upgrades that's most recommended by Tekno Forums users.
If you're new to the Tekno RC brand and about to build your EB410 there are a few required tools. We've detailed the tools you'll need in order to complete your Tekno EB410 build in our Tools for getting started with Tekno RC thread and recommend giving that a read!
Aluminum servo horn - Without a doubt the first EB410 upgrade you'll want to do is an aluminum servo horn (TKR6563A). In fact, don't even mess around with the stock plastic horn and buy the aluminum horn right away.
Aluminum shock caps - I think it's safe to say most people dislike plastic shock caps. They tend to leak more often and easier to mess up if you don't thread them on just right. Add to the fact that aluminum shock caps (TKR6712A) will resolve all those issues, they will also withstand more punishment.
Note: You'll also want to pick up M2x4mm cap head screws (TKR1248) and an emulsion O-ring set (TKR6714)
Carbon fiber top plate - The stock setup is a two piece top plate and doesn't offer the same support as the carbon fiber top plate does. The carbon fiber top plate (TKR6635C) is one-piece and even has a very handy fan mount built right into it!
MIP shock cartridge - The MIP shock cartridge spacer set (18020) eliminates the need to bleed your shocks as often, while allows the shocks to perform more consistently.
These are the most common suggested upgrades for the EB410 on the forum. If you have other suggested Tekno EB410 upgrades, please share them with us below!
If you're looking for the manual or setup sheets, check out our Tekno RC EB410 Manual & Setup Sheet thread.
Recommended Tekno EB410 Upgrades
