jimbulsara
HI all,
Could you run a mamba X on the tekno mt410? or do you necessarily need a Mamba monster x?
Thanks, I will either get the mamba monster X or the Max 8 esc then.I have 2 mamba X and 1 mamba monster X
Use the big boy and you will never have a power concern I run it in a 15lbs Traxxas summit with no issues
I do think the little brother will run a mt410. but at the higher end of its limit. With the larger tires and running the basher king the way it’s meant to be ran it would have a short life in my opinion
Your not going to be racing with it so weight is not a issue. So I would rather have more more power available and not use it then the other way around
