Just wanted to share for general bashing (able to take on the road, into grass, or off decent-sized jumps) I made small adjustments from factory and couldn't be happier. Instead of a "I want to take this off the highest jumps possible" suspension tune, the idea with these changes was to preserve the overall feel of the stock suspension setup in terms of being plush and skimming over bumps without getting unsettled (love the way it kind of rides along the top of rough terrain) but to reduce the front/rear weight transfer a bit. So going up a bit on springs and damping, but mitigating the corresponding understeer by softening the front sway.
Front/Rear yellow springs
Front 825cst oil
Rear 750cstoil
Front sway reduced to 2.4mm
Rear sway still at 2.8mm
edit: F/C/R diff weights at 100k/200k/50k cst
yes, it's a little more tail-happy on loose terrain and I could see dropping the rear sway down to 2.6mm, but overall it feels just as plush as it did before but turns in better. It's also a hoot to put on the minikawas (hugely underrated tire IMO. sometimes less grip == more fun) to get even more on-throttle rotation/oversteer on higer-grip surfaces.
Front 825cst oil
Rear 750cstoil
