Supradude26
I purchased this Losi 8ight-E 4.0 in August of this year, and it was already built but never ran. I installed a Castle Mamba Monster X ESC and a Castle sensorless 2200kv motor. I purchased it strictly to do on road speed runs, and other than that I have run it one time for about 15 minutes on the local outdoor track. Running on a pair of 3s Traxxas batteries with a 23t pinion I GPS'd it at 88.3mph. It's never been bashed and it's never been in a bad wreck. Total runtime is about 1.5 hours, and other than the 15 minutes on the track, it's all been on foam tires. When I purchased it, I did not get the box, manual or any additional parts. I didnt get a body so I purchased a new one of those that is in great condition, as well as a lexan wing that painted to match and never trimmed down, and it has never been used either. The factory wing has been shaved down for max speed. I upgraded the center rear driveshaft to a universal, installed the TLR aluminum front top plate and the newer rear wing mount with a screw down wing setup rather than the body clip version it came with. A couple of months ago I installed a Savox SC-1268sg black series steering servo and a Castle fan on the motor. Since that time I have run it maybe 20 minutes. I will include either the set of foam wheels and tires or the Dynamite Double Barrel pins that were only used the one time I went to the track. Both sets are near new condition. Also included is a set of DE Racing rear mud guards, 2 new DE Racing rear skid plates in addition to the one currently installed on the car, a DE Racing front bumper/skid plate installed now, a new rear gear box housing, some diff gaskets and o rings, the stock front springs as I changed to a stiffer spring on the car, a couple new axle boots with rings, a set of new front or rear cvd shafts, 3 new shock standoffs, extra sway bars and ackerman the stock rear center cvd and all the other stock part I replaced, as well as the stock 17mm hubs as I changed to the wider version that Losi offers. I also have a couple sets of older foam/oval wheels and tires I will throw in, and lastly I'll include the TLR track duffle bag.. If you want a radio system I can include a simple system that came out of a rtr I had, otherwise the car will come with everything needed except a battery and radio and reciever.
Price for everything is $575.00 or $625.00 with a radio system.
