TIME MACHINE
Like new, used only two times. All cables and accessories included. I no longer use this charger due to my not wanting to take it out in the field (so I take my cheap DC charger). This is one of the best chargers that money can buy.
$115 shipped in the USA. PayPal accepted.
Original Sales Info:
The EOS 0720i NET3 AD is the answer when looking to upgrade to more power but where you still have the flexibility of the built-in power supply. The 120V/220V input provides 90W of input power, where as on DC (up to 15V) you have 150W at your disposal.
Features:
Included with the package:
Specifications:
Features:
- Integrated balancer, LBA10/300 with 300mA max balance rate per cell
- TCS & STORE MODE
- 20A Max with 90W (AC) or 150W (DC) charger power
- Network to 300W and 14S max(2x7S balanced)
- Next-generation 0720i NET charger for 110-240V and >15VDC
- Perfect for home as well as the field or track
- Adapter boards for Chinese types (XH) and of course Hyperion is included - two adapters are included (not 3 as depicted)
- USB PC Port for Firmware upgrades
- PC Control & Data Suite Software System, which allows full control of the charger via PC, Data Logging, Memory Management, and more
- Temperature Sensor Port & Temp Stop settings*
- EOS 0720i NET3 7S AC/DC Charger (150w max) x 1
- US AC Cord
- USB Cable
- JST XH 2S-7S Balance adapter
- Hyperion 2S-7S Balance adapter
- Balance adapter harness to charger
- User Manual
Specifications:
- Input Voltage Range: 11-15V DC or 100-240V AC at 50~60Hhz
- Battery Types:
- NiCD/NiMh: 1-16 cells
- LiPo: 1-7 cells (100~6000maH) 3.7v/cell type only)
- HvLi: 1-7 cells (100~6000maH) 3.8v/cell type only)
- LiFe: 1-7 cells (3.3v/cell types including A123 and LifePo4 brand cells)
- PB: 1-12 cells (2v/cell nominal)
- Charge Current: 0.1A~20.0A Max by 100mA steps(150Watt limit on DC, 90Watt limit on AC)
- Discharge Current: 0.1A~5.0A Max by 10mA steps(50Watt limit)
- Trickle Charge Current: 0~200mA (NiCd/NiMh only)
- "Delta V" Peak detection for NiCd/NiMh
- "CC/CV" for Lithium polymer and Lead Acid batteries
- Cycling modes: Charge>Discharge / Discharge>Charge
- Display Type: 2 Line, 16 character Yellow backlit LCD
