Hinge pins
Slevin
Ummm Yeah!
Milwaukee, Wisconsin
So mybhinge puns were pretty nasty and has rust built up on them. When I put them back into the a arms they were very stiff. What do you use to clean them?L and remove the grime so they float freely?
I put them in my drill and hit them with a scotch brite and some WD-40 while on a medium speed. After it is as clean as that it will get that way I decide wether to go another step or not. If it still feels gritty or "caked" then I will use 400-600 grit wet sand paper and do the same thing.
And then polish them back up with 1000 grit and then a scotch brite.
I’ll give that a go!
That's pretty much what I do too..
