405RCDad
Hello, I have my son's eb410 dialed in pretty good for our local track. We run on grey home Depot carpet and the track is usually tight and technical. I'm still fighting traction roll at times and can't seem to keep the inside rear wheel from lifting at almost every turn. The car has the shock forward mod, currently running 1.7 front sway bar and 1.4 rear. Running 1.7 pistons up front with 37.5wt and 40wt rear (AE oils). Car has carbon towers and all the other carbon options installed. I am running the Tekno carbon option rear tower that allows for the shocks forward setup, but it is the standard height version. I have experimented with shock tuning, 50gram weight in the rear, shorty/slim shorty, camber, etc. Still haven't made any significant improvement for this issue. Hoping some of you may have suggestions that may help me figure this out. Also I'm still pretty unsure of what to do with the rear C and D blocks and the rear camber links, since the geometry has changed with the rear shock mod.
