getting ready to place my order
paytonimusrex
this is what I have set to order to any recommendations or changes I should make? I will be racing this car at tracks near me.
tires wise the tekno wheels will be for racing once I figure out at the tracks what tires to use, I will order a set of slash wheels off of ebay to bash around with
battery and charger wise i’m looking at grabbing zeee 6800mah 2s lipo with bullet connectors but I can change it that if there’s a different rec for a battery charger i’m looking at a gens ace
You might need to check the size of that 8 channel receiver. There's not very much room in the receiver box.
I would see how long the mains are as the heavier SCT sucks the life out of batteries. Just for a bit of reference, I will get about 12 minute run times from a 8200mAh pack.
just now seeing these replies never got a notification, I did get that charger that was recommended, the receiver ended up fitting perfectly it is really small actually, I will probably get a bigger 2s at somepoint but the 6800 mah should work for now
just finished building the car today test drove it and then lost a wheel nut lol
