So after a lot of research and even more guesswork, I'm getting started on my build today. What started as an RTR Kraton 6s evolved into this:
Parts List:
1 x TKR5603 Tekno RC MT410 1/10 Electric 4x4 Pro Monster Truck Kit
2 x ARA550050 Arrma BLX 4x4 Backflip LP 4S 3.8 Pre-Mounted 1/8 Monster Truck Tires (Black) (2)
1 x CSE010-0145-03 Castle Creations Monster X 1/8 Brushless Combo w/1515 Sensored Motor
1 x CSE011-0053-00 Castle Creations 6.5mm Polarized Bullet Connector Set (Male/Female)
1 x CSE011-0119-00 Castle Creations Castle Link V3 USB Programmer Adapter
1 x TKR5115 Tekno RC Lightened 44T Hardened Steel Spur Gear
1 x TKR4175 Tekno RC "M5" Hardened Steel Mod1 Pinion Gear w/5mm Bore (15T)
1 x PTK-2111 ProTek RC 30x30x10mm Aluminum High Speed HV Cooling Fan (Silver/Black)
1 x Exotek 1/8 V2 E-Buggy Clamp On Fan Mount (Black)
1 x TKR5253B Tekno RC Aluminum Single Sided Clamping Servo Horn (25T)
1 x TKR5262 Tekno RC CNC Aluminum Split Center Differential Mount (Gun Metal)
2 x TKR6013 Tekno RC Aluminum Shock Adjustment Nut Set (Gun Metal) (2)
1 x TKR6146 Tekno RC CNC Delrin Shock Cartridge Set
1 x TKR6168 Tekno RC CNC Flat/Flat Shock Pisto
2 x TKR6015 Tekno RC Aluminum Shock Cartridge Cap Set (Gun Metal) (2)
1 x TKR6093 Tekno RC 80mm Front Shock Spring Set (Orange) (1.6 x 7.5T) (2)
1 x TKR6083 Tekno RC 90mm Rear Shock Spring Set (Orange) (1.6 x 9.0T) (2)
1 x PRO6070-02 Pro-Line Extended Body Mount Thumbwasher Kit (4)
M2C:
1x m2c 6913 TEKNO MT410 UPPER STEERING PLATE
2x m2c 6901 TEKNO ALUMINUM FRONT/REAR DIFF CASE
1x m2c 6755 TEKNO SHORT REARCENTER BRACE FITS MT410,.3 BUGGY,TRUGGY
1x m2c 6760 TEKNO MT410 FRONT UPPER SHOCK TOWER BRACE
1x m2c 6770 TEKNO 48.3/48.4 16MM ZRS SHOCK CAPS
1x m2c 6835 TEKNO GAME CHANGER V2 MEGA BRACE
1x m2c 6900 TEKNO MT410/ 48.3/48.4 ELECTRIC CENTER DIFF CASE
1x m2c 6970 TEKNO MT 410 V2 GEN 2GO BIG REAR TOWER/ CHASSIS STIFFINER KIT
1x m2c 9130 DROOP SCREW SOLID MUSHROOM HEAD STYLE
Other:
1x Tekno MT410 AllRacing Gearbox (ebay)
2x Boca MR696-2RSC
2x Boca MR695-2RSC
1 x Unbreakable Body for HPI Savage Chevy C10 and Tekno MT410 (ebay)
1x TBR Basher Front Bumper - Tekno MT410 Pro Monster Truck - 57017
1x TBR V2 Stunt Truck Rear Bumper - Tekno MT410 - 57030
1x ProModler DS630BLHV Servo
RX/TX:
FS Flysky RC Noble FS-NB4 Remote Controller Radio Transmitter for Rc Car/Truck/Boat w/ FGr4P Receiver, Transmitter Battery
Fluids:
1 x ASC5436 Team Associated Silicone Shock Oil (2oz) (60wt)
1 x ASC5459 Team Associated Silicone Differential Fluid (2oz) (100,000cst)
1 x ASC5458 Team Associated Silicone Differential Fluid (2oz) (60,000cst)
1 x ASC5457 Team Associated Silicone Differential Fluid (2oz) (30,000cst)
1x Lucas Oil Red "N" Tacky Grease, 1 Pound Tub, 16 Ounces (LUC10574)
1x White Lightning Clean Ride The Original Self-Cleaning Wax Bicycle Chain Lubricant
1x LOCTITE 243 x 50ml Medium Strength Oil Tolerant Threadlocker
Tools:
1 x TKR1119 Tekno RC Hardened Steel Turnbuckle Wrench (5.5mm & 7mm)
1 x TKR1116 Tekno RC 17mm Wheel Wrench & Shock Cap Tool
1 x TKR1115 Tekno RC Aluminum Pivot Ball & Shock Multi-Tool
1 x TKR1103 Tekno RC Hardened Steel Turnbuckle Wrench (4mm & 5mm)
1 x KYO36262B Kyosho KRF Stainless Curved Lexan Body Scissors
1 x KYO36261 Kyosho KRF Stainless Straight Lexan Body Scissors
Charging:
1x Heavy Duty AC Power Cord for Mean Well Power Supplies
1x Male XT90 to Ring Connector Power Adapter
1x Mean Well RSP-1000-24 Power Supply
1x iCharger S6
Lipo:
2x SMC True Spec Extreme Graphene V2 14.8V 8000mAh 120C hardcase - Connector Options: 6.5mm Polarized
Unused parts:
2 x ARA310452 Arrma CVD Rebuild Set (2) (I couldn't source the retainer rings so I'm skipping 0verkill's mod for now).
1 x TKR4177 Tekno RC "M5" Hardened Steel Mod1 Pinion Gear w/5mm Bore (17T) (shouldn't have ordered)
1 x TKR4176 Tekno RC "M5" Hardened Steel Mod1 Pinion Gear w/5mm Bore (16T) (wanted to try 16T eventually)
Should everything come together, I hope this list helps people just getting started because the amount of time spent researching was obscene. I'll be posting my progress along the way and I'm sure I'll have a question or 10 along the way.
Thanks to everyone on the forums past and present for the information that got me this far. Also props to Amain Hobbies for running a really fine business. The vast majority of my parts are from their site.
If you see anything wrong with the list or build that I screwed the pooch on, feel free to let me know. I can take it and hope to learn more along the way. The barrier to entry on this project was surprisingly large (and growing).
Parts List:
M2C:
Other:
2x Boca MR696-2RSC
2x Boca MR695-2RSC
RX/TX:
Fluids:
Tools:
Charging:
1x iCharger S6
Lipo:
Unused parts:
