Redrumracing
Looking for some help to identify what is causing wheel wobble in both front tires. Just finished build on ET 482.0. Set the end points and took it for a test drive. When driving straight there is zero wobble. Slight turn left or right and both wheels are wobbly. When wheels and tires are not mounted there is very little play when trying to move the hubs. When wheels and tires are mounted there is significant play when turning the wheels by hand. Is it common to shim the hub? Any suggestions would be appreciated. Wheels and tires are proline buckshot pre mounted. Thanks.
