ET410.2 rear shock tower carbon fiber
Emulcahey1
Warrenville, IL
  2. ET410
I’m on page 10 step F-6 setting up for carpet.
Installing:
TKR7282C carbon fiber tower
Exotek ETK2023 rear hub set
I noticed the holes for the 12mm ball stud to go through unless I install the tower on the tower without the tkr6666 camber link. This is the first time I have messed with carbon fiber parts. Any and all help is welcome.
With the carbon tower being drilled for the camber links you would not use the aluminum plate.
Thank you Nub. I wanted to make sure before I ran it.
