ET410.2 Rear Mounted Shocks On Rear Arms/Tower
central PA
  2. ET410
  3. SCT410
For those that own the ET410.2, and running on loose surfaces, are you moving the rear shocks to the rear of the arms/tower like that of the original ET410?
Not worrying about the anti sway bar arrangement, but is moving the rear shocks to the rear of the arms/tower just as simple as buying the ET410 TKR7224 rear arms, and reaming out the inner hinge pin holes?
Thanks to Kevin... "Yes (it is as simple as using original ET410 arms on the ET410.2 and reaming out the inner hinge pin holes to 3.5mm). It's a common mod that we do at our local track. 99% of us have done it. A lot of guys will also put the old hubs on too. I bought the exotec aluminum hubs for the 410."
