Great bro. ThanksHi,
No problem with the diffs.
The hub will rub though. You will need the +2 mm hexes. https://www.amainhobbies.com/tekno-...b-set-gun-metal-2-2mm-offset-tkr5071c/p250432
They also are slightly taller and heavier than race tires, so you may want to watch the motor temps. Drop a teeth or two on the pinion if you are already at the edge.
The original ones are “+0”.Great bro. Thanks
So if i need 2mm hexes...how muck the original hexes..(by the kit)
