gutrageous
Hello all,
I've run into a minor(?) issue on my new 2.2 build. Installing the front shocks using the correct 8777B (longer standoffs) the shocks are still in a bit of a bind from the far forward (new?) position of the lower pivot. The slight binding of the shock may not be much of an issue and will break in but the "large" angle of the shock (front to back) is resulting on the lower spring cup rubbing on the uni dogbone a bit. Not much but definitely dragging.
Hope I'm describing the issue clearly. It looks like just a bit more on the top standoff to straighten up the shock a bit would fix. Anyone else run into this? If not, any idea what I might have done incorrectly?
