EB48 2.0 and Protek 170 SBL Servo
Sacramento California
EB410, EB48
I recently bought a Tekno EB48 2.0 and am having a blast building it. It is a very smooth and easy build with one exception. I am running a Protek 170SBL servo ( https://www.amainhobbies.com/protek...high-speed-brushless-servo-ptk-170sbl/p507825 ).
Where the plug goes into the servo it is partially obstructed by the mounting posts for the ESC tray (TKR9065). I watched a build video on you-tube where the builder talked about having the same issue. He said he dremeled out part of the posts but did not show any pictures or give further information. Has anyone else run into this issue? Have any pictures? I really love the Protek servos and am looking forward to getting my sweet new ride on the ground.
Thank you in advance for any information you can provide.
EB410, EB48
Just in case anyone else runs into this in the future. I put the servo into the mount and marked (roughly) where I needed to open up the mount so the servo wires could come through on the inside of the mount nearest to the front chassis brace. I used a cone shaped 1/4 inch grinding stone to remove some of the material. I ended up using a dremel sanding wheel to finally get it to the right size. The hole was not as "pretty" as I would have liked but it can not be seen.
It is a tight fit for the servo wire, it touches the front chassis brace. I was able to route the wire along the back side of the servo, through the wire hold downs and into the receiver box. The wire is a little tight but shouldn't be too bad (not straining). I tried to wiggle the servo/esc tray once it was back into the vehicle and it seemed solid. I still have to test it under "working" conditions.
Skynet5
I had the same issue with the KingMax B01S. Thankfully with a bit of light persuasion and rotation of the cable it fitted it. It was the rubber boot at the servo that the cables go through made it hard to fit.
R 48 2.0 Need some help with bag i EB48 2.0 EB48 13
A New EB48 2.0 EB48 2
Kronuxx EB48 2.0 gearbox mount holes? EB48 6
S 48.4 EB48.4 Ride Height EB48 2
Sludog Tower hobbies has EB48 2.0 in stock.......Hurry if you want one EB48 5
Ifti 48 2.0 Tekno EB48 2.0 Complete Video Build Guide! EB48 24
S 48.4 First Tekno kit. EB48.4 EB48 3
N First build eb48 2.0 RC Builds 7
Stevie'sDad03 EB48.? EB48 7
T Eb48.4 vs eb48 2.0 EB48 12
N 48 2.0 Esc dimensions eb48 2.0 EB48 9
J 48.3 Help with steering please (Eb48.3) EB48 7
HeavyBag EB48 Picture Thread EB48 31
TBuggy 48 2.0 TBuggy's EB48 2.0 EB48 50
Ifti EB48 2.0 Electronics Setup? Electronics 50
Y 48 2.0 First ever kit completed: EB48 2.0 :D EB48 8
Nicochau EB48.2 spindles upgrade EB48 5
R EB48.3 noise levels EB48 3
Y EB48 2.0 Setup sheet PDF? EB48 3
DangerD EB48.4 or 2.0 EB48 15
Ifti EB48 2.0 or EB10.2 ? RC Builds 9
Jared wagner Eb48 2.0 / mt410 MT410 0
G 48.4 Anyone have m2c on eb48.4? EB48 4
TBuggy EB48 2.0 EB48 16
H EB48.2 and EB48.3 Parts Compatibility EB48 6
B EB48.3 or .4???? ET48 4
Nicochau Would you recommend EB48 “.1” to a friend? EB48 1
E EB48 2.0 EB48 4
Budki Sct410/ EB48 parts list SCT410 13
Tamiyauberalles 2.8 1/10 Monster Truck tires on EB48? EB48 27
Overkill Monster EB48.3 buggy RC Builds 50
S Basher buggy build: ET48 to EB48 conversion? Parts list? ET48 4
D I want to use Exotek hubs on my EB48.3 EB48 10
Tamiyauberalles Got a used EB48.4 but the body is shot, options? EB48 7
Tamiyauberalles MT410 - EB48.4 common parts? EB48 3
matimath Rumors of a Tekno EB48.5 EB48 22
B Best wing for EB48? EB48 3
Nicochau Wheels rubbing on EB48.4 EB48 2
C 48.4 EB48.4 is fantastic EB48 9
Bastien Eb48 to desert buggy EB48 12
C EB48.4 to SCT EB48 8
StevieGT 48.4 95% done with EB48.4 EB48 19
cdaxj Question about SCT410 vs EB48.4 SCT410 6
StevieGT EB48.4 Couldn’t resist RC Builds 14
D Buying EB48.2 EB48 5
TBuggy Tbuggy's EB48.3 EB48 7
T Weight of naked chassis EB48.4 / EB48SL EB48 2
S Wrong shock bodies on EB48.4 EB48 9
J What diff oil weight for speedruns? Tekno EB48 Chassis & Drivetrain 2
Talon4U2NV EB48.2/.3 EB48 11
