differentials not fitting into bulkheads
Len Sharp
The completed differential is 1/16 too large to fit into the bulkheads. It appears the gear assembly is a tad too large as the differential does fit if I take the gears out.
This is the same case for both front and back units.
It sounds like something is just not seated correctly when you are closing it up.
If you post some pictures, it will help us help you.
Thanks, A hammer and the head of a nail pushed it in just enough.
