Thought I would post here rather then start another new thread - but when it comes to greasing the o-rings that go inside the differentials - is it best to use the black grease thats supplied with the kit for everything to do with the diffs?
I have some shock o-ring grease too, which I was going to use for greasing the o-rings in the diffs, but notice most use the supplied black grease with the diffs?......
I'm guessing you viewed someone using grease in their gear diffs, and their diffs were probably not the sealed type. Having a gear diff that does not use o-rings and gaskets is the only reason to use grease IMO.I've seem some users fill their diffs with synthetic grease rather then oil.
What are the benefits, or drawbacks to doing this??
Grease lets your diffs all turn free or "unload" easily. Grease lubricates better than silicone oil too so you get less wear.
This is kind of an ambiguous statement because there are many different brands of grease as well as silicone fluids and I'm not convinced that the best performing brand of grease will provide any less wear than the worst performance brand of silicone fluid. In contrast, I feel that grease unloads more and will spin up to were the center diff will be more likely to over heat and melt the plastic where if you were to use thicker silicone fluid then you would be less likely to over heat the diff which in turn would be less wear with silicone fluid![]()
