410.2 Diff Height Riser
rfulcher
Greencastle, PA
  4. MT410
  5. SCT410
I see reference to Diff risers, but I can't seem to find any. I would like to raise the diffs 3-4mm up for a ride height of 12 mm. Does anyone know where
I don't race the EB410 anymore, but back in the day, VRP had offered custom shock towers that were +4mm taller so we could get 12mm ride height. Those towers are no longer made, but if you design the CAD drawing and send me the DXF, then I can cut a tower on my CNC, or you can do it all yourself too:
Is there an easy program to create CAD files in?
follow the link I provided above, I use CamBam
understand that if your measurements aren't perfect, it may take several tries until you get a good fit, I typically do my test runs with less expensive Kydex and then cut carbon once everything is good
