Center Diff
Driving my Senton 3s for some projects, and thinking about getting the Tekno SCT. One question I have is how much differences does having a center diff make? I don't have another 1/10 with a center diff to make a comparison. My Nomad DB 8 is an absolute joy to drive, but it's so different than the Senton that I can't pick out the affect the center diff has on my Nomad to identify it missing in my Senton. I'm not sure if that makes sense.
I'm tracking down a better testing platform for some projects, and while I love my Senton 3s ( heavily modified ), it still handles like a sled. I want something more nimble and responsive. I don't bash, and I really don't even jump.
Thanks.
Having a center diff will make the car easier to drive in low traction conditions, more info here from HUDY Setup Guide:
Excellent. Really had to work getting my Senton to handle today on loose, small gravel over hard pack dirt. Once this platform dies, I will switch to a SCT with a center diff.
s
ReMiXeDg Is the MT410 center diff is it suppose to feel a little tight? MT410 4
D 410.3 Worried about center diff, help? SCT410 4
Tamiyauberalles Had to shim my center diff EB48 0
S Center diff mount question MT410 1
Traxxas2Tekno Mt410 center diff upgrade MT410 4
cordell12 m2c Center Chassis Brace broken at center diff Chassis & Drivetrain 60
Jared wagner Aluminum split center diff mount MT410 13
B Rear center outdrive leak 48sl Chassis & Drivetrain 2
Slogrits Revised M2C center brace MT410 13
cadon78 48.3 Battery strap rubbing center front drive shaft. ET48 12
S diff fluids for bashing around on the street EB410 15
T How on earth did this happen? rear diff gearbox issue? MT410 15
ReMiXeDg run the stock diff oil or change it? MT410 6
Ifti Diff oil or grease? Chassis & Drivetrain 5
DangerD Spidergears in Rear Diff keep blowing Chassis & Drivetrain 13
Desmobullet69 New rear wing, mounts and diff housing after light crash ET48 1
B MT410 Diff Fluid? MT410 1
Desmobullet69 Bashing Diff Fluids ET48 4
Tamiyauberalles So I broke the rear part of the rear diff case. EB48 3
E 48.3 Ideas for diff oil high traction ET48 9
WoodiE Tekno Hardened Steel Diff Case Chassis & Drivetrain 4
Davo Turner Diff problems Chassis & Drivetrain 1
Coopsonthefarm Diff question? MT410 3
Cody's mt410 What is The perfect diff fluid MT410 2
louielc Front Diff Possible issue, should i worry? MT410 6
maxxis Rear 1mm and 2mm diff shims EB410 2
keoni068 Diff tips? MT410 7
M Diff setup for ET410 ET410 2
J What diff oil weight for speedruns? Tekno EB48 Chassis & Drivetrain 2
M Front Diff problems MT410 16
cordell12 Anybody ever blow out a inner bearing in diff case? Chassis & Drivetrain 11
S Diff Oil Leak & Signs of Overfill Chassis & Drivetrain 8
WdotDynamite Composite Diff Gears. EB410 4
gearhead455 What diff oil weights do you run? EB48 10
