Best motor for 5-6s?
NoDa75
I have wanted a motor for the MT410 that is good for mainly 5-6s use, sometimes 4s. I have heard good things about Posiden, TP, and others. I was wondering what experience y’all have had with what motors. Price range is about $120
Nicochau
EB48, ET48
With that voltage you probably will want to get a larger 74mm "Truggy" can and ~1700kv.
I raised the same question multiple times and on multiple groups. Here are the learnings I'm gathering so far:
  • Generic brushless motors are getting better and better. Some $35 cheapies from eBay will perform close to the $100 stuff (I confirm)
  • In that voltage range, cogging is not an issue. For a basher you definitely do not need it to be sensored. Save the money and the extra cable array.
  • More expensive motors will run cooler and longer run times (not tested)
  • Choosing the right kv range for the application is really what it is all about. Extreme values will be hard to compensate with tiny pinions or fans.
Some of the brands getting love these days: HobbyStar (good value), Castle knock offs (non-sensored), legit Castle (sensored) and of course TP, which sits in your ballpark price wise.
smirkracing
EB410, EB48, ET48
That's a wide voltage range. It will be tricky to select a motor that can handle a 50% increase in voltage (4s to 6s) given the somewhat limited pinion range on the MT410.
If you have a lot of packs at 4, 5 and 6s, and you want to use all of them, then you might want to to dial in your motor selection for 5s with an 18t pinion. I suspect that you'll want to get down into the 1400kv range. That gives you the room to increase to 20t or more for 4s, and to drop down to 15t on 6s.
I have a TP Power 4050 motor (81mm, 1700kv) and it gets too hot on 6s with a 15t pinion.
In terms of brands, I've tried Tenshock, TP Power, Cordova Research. My favorite is probably Tenshock, although to be honest, they're all just fine, and I don't see a big difference between those brands. The Cordova motors are very pricey and I am not sure they deliver that much more performance. Over time I've ended up owning more Tenshock motors than any other brand - they seem just right to me in terms of fit and finish, they have decent parts support, and they're very reliable.
Mt410dude
Have you tried the 812 l ? If so how did you like it
NoDa75
Thank you! I own a mini ten shock motor for my 1/14 car. Good quality. About 1500kv would be good then?
smirkracing
EB410, EB48, ET48
I have the x802, which is similar... great motor, but not nearly big enough for a basher based on the ET4.8, which gets to be pretty heavy. The tires for that chassis are pretty large (6in on the low end, often 6.5" or more, even) so your final gear ratio ends up being pretty high, and my temps were out of control with that motor.
Probably.... but depends on your tires and driving style. If you run huge tires and big battery packs, and you want long run-times, then you need a pretty hefty motor (in terms of length).
ReMiXeDg 48.3 best motor and esc combo ET48 2
lampshade9909 Best non-Tekin ESC that fits in the ET48.3 with a Tekin motor? Electronics 21
Hye Best fan for motor? MT410 11
Will Best Tekno Corona/Christmas ever! EB410 1
SHWA Best Charger Options for 6S 5000mah batteries Electronics 24
Sludog Some props from MSM on the MT410, best monster truck ever! MT410 6
BashingBrian Best bashing ESC for MT410 Electronics 9
ReMiXeDg Best wheel set up for ultimate basher? MT410 5
Papi Chingon Best way to accurately drill mounting holes in unbreakable russian body? MT410 4
B Best wing for EB48? EB48 3
K There is no techno 2wd buggies for racing. What would everyone choose as the next best option i should buy instead? I'm willing to spend the money.. EB410 11
Slogrits Best battery connector Electronics 23
antigacho Best transmitter for EB410 / budget around $200 Electronics 19
colbythenoob best budget transmitter around 100 dollars Electronics 18
Marius van schaik What is the best way to paint a body? Paint and Body 22
MikeBuzz DB48 ESC and Motor Choice Electronics 7
BashingBrian Motor choice..? MT410 5
W Motor/esc combo for a newb MT410 6
cAn”t DrIv3 4 sH!t cOol Fast motor EB410 2
N 48 2.0 Motor / ESC and early upgrades EB48 9
J Will this motor / esc fit in MT410? Castle MT410 6
Sludog Anyone have photos of Arrma BLX 185 motor and ESC setup MT410 6
Sludog MT410 build kit coming, need some motor buying advice MT410 11
DangerD New Motor for 6s MT410 19
GeekedupFL Howdy , first Tekno , looking for esc/motor suggestions ET410 3
wjb111 EB410 motor fan EB410 4
lampshade9909 Do you guys run motor heatsink & fan or just a fan? ET48 4
E Motor/ESC limits.. ET410 3
G Motor cogging, radio the cause? ET48 8
G Metal clanking sound, motor turns, wheels barely.. ET48 16
P Waterproof motor & ESC for ET48.3 and Grass running ET48 7
P Waterproof motor & ESC for ET48.3 EB48 1
ZUMA Castle 1515 Sensored Motor, Whats A Good Motor Fan? MT410 0
S Hello, new to forum with motor esc question MT410 Electronics 11
M Fan Mount for Hobbywing 4274 Motor MT410 5
Mesfume I Can't find a Motor Fan that fits. MT410 14
Tamiyauberalles 48.4 Does anyone feel the need (and managed to fit) a fan on the motor in their buggy? EB48 7
Ballistic1 Yes another newbie - plz help with choosing Tekin esc & motor ET410 2
C Pinion size and motor temperature Chassis & Drivetrain 4
I Motor Fitment ET48 9
S New ET48 build, basher, long can motor ET48 28
Brandon motor kv question MT410 8
Slevin Picking a new motor Electronics 6
Hye 410.3 Need help picking a motor to race with. SCT410 3
1 Sct410 motor in reverse? Electronics 6
keoni068 Motor Size and Gearing Differences Electronics 1
V Mt410 esc and motor? MT410 32
Fnfancy Motor keeps breaking MT410 6
cordell12 Motor heat problems Leopard 4092 1480kv 3.5D wind Electronics 29
TIME MACHINE MT410 motor - 2 poles or 4 poles? MT410 12
